290X 8GB agreed a great card but the power draw and heat lets it down
The difference between a 970 and a 290X power draw wise is the same as an old fashioned light bulb.
Do you game in the dark ?
Oh if EVGA are offering a "step up" I'd be interested in that, better go take a look or if anyone has link?
My guess is memory demands for the next few years will hit a bit of a plateau now that the next gen consoles are with us and probably won't spike again until the following generation of consoles.
The 6 million $ question is will this generation of consoles have that plateau at >3.5 or >4GB?...and how long will it take to get to this plateau. This would make a significant difference to the value/longevity of these 3.5/4GB cards.
Is the smart money on a £319 8GB 290x...or a £200-300 3.5/4GB 970/290X...
if were at less than 3.5GB in a few years time then the 970 has got to win hands down in bang for buck, if we cross 3.5GB within a year then 4GB 290x would be better and if we cross 4GB within a couple of years then 8GB 290x looks like best bet.
Assuming you see value as "buy it and run in into the ground", rather than "trading up".
The only signpost i have seen is the technical press reporting that current gen consoles are capable of assigning more than 4GB of VRAM..but not that they would (likely or otherwise).
What you need to remember is that 4gb console port ends up needing more that 4gb on the pc lately with some devs. Personally i think any card with 4gb or less of Vram will have a short lifespan for the user who likes high resolutions/graphic detail. I'd agree if i wanted a long term rig atm 2+ 8gb 290x's would be my first choice
Please. Manners cost nothing chap![]()
I really know little about gfx cards compared to most of you but i'm still unsure what to do. I'll most likely be gaming at 1080p but maybe higher at some point.
With this NVIDIA memory debacle, am I likely to encounter stutter and performances problems running at 1080p ultra settings for most new games? Is the 970 likely to hold its own for games coming out this year and next?
I, like most feel like i've made a bad purchase, but returning it isn't quite a viable option for my system
The PSUs in my PC could run 4 x 295X2s but the crossfire profiles are just not up to it.
Bit of a bummer what has happened and it's nice yo see OcUK putting the customer first, props! I'd have stuck with AMD had this been apparent when I got my 980, I know that has no issue but I go by principals.
On a lighter side, this just popped up on a feed
https://www.youtube.com/watch?v=spZJrsssPA0
With 4 x 290X's I could heat the entire village, i'll think ill pass and keep with my future 980![]()
Ok that sounds great (now I have to find out if another UK shop is offering the same opportunity as I've bought the cards from different places).^ End of Feb
