It's more of a side grade, some might say an upgrade over the 970s 3.5GB of ram![]()
http://www.anandtech.com/bench/product/1355?vs=1059
...ah you linked to a Uber mode test comparison. I had to look to see what that meant....
Dude you just bought a 4gb 290x in MM. Why?
It's a downgrade on your gtx970 !
Dude, because its a tide me over until the 3XX series comes out
Not seen that before. Brilliant.
I concur... single 970 to single 290X is just pointless, especially as a "tide you over" card. Should have just kept the 970 if you're upgrading in 6 months time, probably be worth the same by then anyway. I don't get why people seem to be reacting as though the 970 has become, or is soon to be, a useless card?! It will be great at 1080p for AGES yet, and won't be any the less desirable to the vast majority of gamers in 6 months time. This forum seems to create the impression all gamers are at 1440P+ and SLI'ing cards left, right and center, slamming up against the 4GB limit on a daily basis, it's ridiculous! The reality is that 90% of gamers as a whole are still at 1080p and know NOTHING of the 970 fiasco, nor do they care.But then won't you lose money on the 290x ?
175 on a tide you over card is epic....I think you've rushed into it...
1440 p gaming is still niche and there is no better 1080p card than the gtx 970
Yeah i agree Legend pointless in changing your 970 if you're gaming at 1080p but what do you recommend for people who are going to buy a complete new system and will be gaming at least 1440p?
This
http://www.overclockers.co.uk/showproduct.php?prodid=GX-353-SP&groupid=701&catid=56&subcat=1752
And if needed add a second one later.
Because that is only 4gb per gpu.
I would go this rather than what Kaap posted, can't be £100 better.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-269-MS&groupid=701&catid=56&subcat=1752
I'd agree, if you MUST get a new system today, the Vapor-X OC 8192MB will offer you the most longevity, but it's only really worth getting an 8GB if you're getting x2 of them, otherwise 4GB is enough. You'd run out of GPU grunt before you utilise the 8GB anyway. If you can wait though, worth seeing what the 3xx series will bring around June time. You could always get a cheap card as a stop gap until then. An alternative to the Vapor-X 8GB is the MSI 8GB card, which is quite a lot cheaper. As someone has previously asked, I don't know that the Vapor-X is £100 better, although I believe it does have a superior cooler, I've not seen them directly compared.This
