HI Chris,
Please provide me with the exact spec and model of memory and I will forward the info to Gary Key, perhaps he can try the same and report back any issues.
I have searched back through the pages, but could not find any info as to how you are setting up the ram before you try to save and reboot.
It looks like you've tried everything already.
I assume the only way you can change bios memory settings is to boot with the cheaper ram.
If you have not already done so, put the working ram back in and reboot into bios, relax all clocks manually, including htt etc,
go into memory and set clock speed, and latency manually, also anable the 2t command. Save the bios but don't let it reboot (make sure it has saved before you switch off though), turn off the computer at the mains and try installing the corsairs and see what happens. If you have already tried all this, which does seem likely, then ignore me, only trying to help.
If the above has already been tried, the best course of action if you still want to try and get things working, is to try and get someone else to re-create the issues for you.
At a long shot, and maybe not attractive to you, is to send the ram to either myself coolasmoo or Lordedmond, we can the see if we can get it to run on our machines and post it back to you. We can at least try to help............
First port of call will be Gary Key, I can forward his contact details to you privatley if you wish, email me......
Raja
Sorry we did not pay enough attention to your problems earlier, we were all preoccupied with our own issues, to provide any in depth help or advice.
