Had a proper (feel free to substitute the word "noob" for proper
) go at overclocking this board last night... and believe it or not I can't get it to perform any better by using manual overclocking than the AI N.O.S. can do it automated.
With AI N.O.S. at 10% I get 13x 220Mhz = 2860 Mhz, with RAM clocked at 220 MHz 3-3-2-8 1T. It's dual channel ram so i guess that's really 440 Mhz?
Doing it manually I dropped the default x13 multiplier to x10 and managed to get the HTT up to 295 for 2950 MHz, at which point I had to increase DDR Volts from 2.6 to 2.65 to get it stable. But it just would not go to 300
I couldn't get the multiplier up to 10.5 from there either, although I didn't try more than 1.4 Vcore as I've no idea how much an FX60 is supposed to be able to take.
Also, at 2950 MHz, I could not change the memory clock from being limited at 133Mhz in the bios setting, without all kinds of weirdness happening. Like for instance my X1900XT-X telling me it had a duff bios! There was a small amount of panic when that happened, I tell thee.
CPU-Z reported memory frequency as 196.7MHz at that point (?), and running 3DMark'06, super Pi and then having a quick blat on Oblivion proved there was no real gain between either the manual setting or the AI setting. Trouble is I know even less about clocking memory than I do about cpu's... so this is a learning curve for me
If anyone knows of any good guides about clocking memory, link me up I'd appreciate it
I haven't fitted the watercooling setup I bought yet, but I'm not sure I'll need to. If Asus Probe is to believed, the cpu temp never went above 39 and the motherboard stayed at 34 the whole time lol. I feel like the cpu wants to do more but something is in the way (apart from my lack of knowledge). Just don't know what that is yet :/
