- 15 Jan 2004
- Hall
What speed ADSL you got? And what speed does it sync at?Radiation said:snip
sam.wheale said:Actually, thinking about it if I were to try upgrading to 2 MB MAX through Pipex, would that entail agreeing to a new contract with them?
SW.
Phnom_Penh said:What speed ADSL you got? And what speed does it sync at?
tolien said:Whether you're capped to 1Mbps is irrelevant...
Login to your router's web interface, then goto http://x.x.x.x/adsl_status_main.stm , replacing the Xs with the ip.antc said:snip
Phnom_Penh said:Login to your router's web interface, then goto http://x.x.x.x/adsl_status_main.stm , replacing the Xs with the ip.
It estimates you can.ruffneck said:snip
You need about 8db of SNR for each double of speed.Caged said:Is that figure an official one? I'm the other side of town from my exchange, and my router's reporting:
SN Margin (Up/Down) [dB]: 31,0 / 26,5
Will be interesting to see what we get.
find out yourself here http://212.23.23.177/calc.htmruffneck said:Can anyone make sense of these?
(ie) convert them to my chances of getting the full 8mb?
DSL Status
Connection Status Connected
Upstream Rate (Kbps) 288
Downstream Rate (Kbps) 2272
US Margin 28
DS Margin 28
Modulation MMODE
LOS Errors 0
DS Line Attenuation 38
US Line Attenuation 39
Path Mode Fast Path
Damn dlink router
tolien said:Yes, they're very good. Expect you'd get the full 8Mbps.
I'm currently looking at the Billion 7402 range, feature packed routers with a decent CPU.antc said:excellent.
what routers do you guys suggest. i have seen the newer version of my belkin, a netgear rangemax one and the speedtouch i mentioned in my previous post.
im not quite upto date with my router info at the minute so looking for suggestions
cheers
