thanks of pointing out the ovbious twicePhnom_Penh said:if you say so, but imo £39.99 is taking the ****.
I'm just emphasising the pointsja360 said:thanks of pointing out the ovbious twice![]()
sja360 said:Got this from plus.net via email after selecting to regrade to option 3 upto 8mbp premier £39.99
does that mean i'm being upgraded or not? as its saying its been rejected but then says about manually updating their systems
although on the plus.net ticket viewer it states 7th april for an upgrade afaik, just a shame they didnt reply saying - "yo its gettin upgraded on the 10th of april mmkay" instead of that ^^
PiKe said:That's your current sync speed, you're connected at 8mbit down 800kbps up.
find out yourself here http://212.23.23.177/calc.htmlego said:ADSL Link Downstream Upstream
Connection Speed 2272 kbps 288 kbps
Line Attenuation 47 db 12.5 db
Noise Margin 17 db 25 db
just wondered what i'de likey get?
legend_of_chaos said:Im with BT Yahoo at the moment and i have 1meg,i have checked on bt's site and it says im able to get just over 3meg on maxdsl,how can i find out if btyahoo are doing maxdsl???,cheers.
ADSLguide said:People are seeing their ADSL line connect to the exchange at the maximum rate the line will manage (this is the ADSL line sync rate), but the actual download speeds from sites like our own speed-tester and others are remaining very close to 2Mbps. This is because of something called the Data Rate, which is set inside the BT Wholesale network and controls the amount of data that each line can carry over the wholesale part of the network.
The Data Rate on a Max product is set initially to 2Mbps, and should change within around 75 minutes of being regraded and the ADSL modem connecting rise to reflect the increase in line sync rate. Currently this does not appear to be happening, the precise reason is unknown, but certainly service providers are aware of it (note: some support staff answering the telephones may not know, it will depend on the briefings given to them by their team leaders).
so once your regraded it starts off at the 2mbp data rate then re-syncs every 75 minutes to "up" it, testing the line till it gets a stable data rate throughout the 10 day test period?tolien said:
