Damn that's a lot of pipes and wires. Good work.
What's your floor build up going to be? I assume you're not going to tile directly onto that chipboard.
Underfloor heating going in?
Sorry if I've missed all that in the rest of the thread.
18mm chipboard (p5/waterproof grade)
6mm decoupling membrane
Tiles on top
No not bothered on underfloor heating... The heating circuit runs under the floor so I suppose it's heated that way
Fitted more floor today and change some old electrical junction boxes to newer style wago boxes "maintenance free" although I realise they are only rated to 24amp for the 2.5mm squared cable so either need to find alternatives or de rate the MCB (only for upstairs sockets so fairly minor)
Im trying to work out now how to fit a shower drain at the other side with no access from the underside, wondering wether to use a Flexible drain coupling also (to allow some minor deviation in height)
