- 3 Nov 2010
thank you
No worries @sunshinewelly (great user name) - have you decided on a combination of components?thank you
It's not a waste but quality air with adequate case fans will get the same cooling results.yes i saw that one - there are a couple on my list. can you recommend a 240m radiator or a 360 one (depending on the case i end up getting ) or is that a waste on a ryzen 2700
Yep, as mentioned if you have the right case airflow combined with a decent air cooler they really produce efficient cooling solutions.After looking at some videos last night I was surprised to see that a good air cooler beat a number of AIO
Excellent coolers: superb design and quality - but questionable colour choice, but has become a mark of quality. But, there are equal quality models and cheaper alternatives if needed.Noctua came up trumps
Yep, the maximum cooler height for the NZXT H500 is 165mm. The H7 Plus would fit easily as only 145mm.Cryorig H7 Plus - would that or the smaller H7 model fit the H500 case - the case refers to 165mm clearance but not sure what that actually means
That Sythe is designed that it steps back from the DIMM slots - plus boards use the second slot further away from CPU slot by default (your Tomahawk being one of them) - so it's not normally an issue, as most users only use two sticks.does clearance take into account the space between top of CPU and case or CPU and ram. I just want to make sure what ever cooler i get will fit. Also do air coolers come with thermal paste or do i need to buy some
No, if you have no need for the WiFi.is the carbon MSI worth an extra £20 over the tomahawk. also as i am getting a cooler do i need an x470 board. (is x470 more future proof or offer a better deal than B450)
The Gigabyte doesn't have the same quality VRMs as the Tomahawk but does have improved built in amp - ALC1220 codec and Gigabyte has UK RMA and great forum representation.I notice the GIGABYTE X470 AORUS Ultra Gaming is £124 - again is that going to be better than either MSI efforts
Mugen 5 is as good clearance high end cooler as they come.does clearance take into account the space between top of CPU and case or CPU and ram. I just want to make sure what ever cooler i get will fit.
Unlike Intel limiting features quite heavily outside the most expensive chipsets AMD doesn't do that, so B450 isn't that much worser in general.is the carbon MSI worth an extra £20 over the tomahawk. also as i am getting a cooler do i need an x470 board. (is x470 more future proof or offer a better deal than B450)
Great choice - quality components and a nice looking board to boot.cheers - will definitely get the carbon pro then
