- 3 Nov 2010
cheers for the links. As far as the fans are concerned i feel an idiot as they were actually spinning. I was used to the sound of my old pc that i assumed they were not moving (what i had taken to be stationary fan blades were the fan case frame )
my system seems solid with the memory at 3333 and the cpu running as standard. However when i change the ratio from auto to anything higher than 35 then my system will not even boot. (so thats a small 300 htz OC)
however thats leaving the voltage well alone and just changing the CPU ratio etc. I had assumed i could run this type of OC without touching the voltage.
also what is SOC max?
The strange thing is that if i press the game boost button that applies a 400 booast to the CPU and that runs fine (even with the ram at 3333) - i dont know what options game booast changes - i know that it takes over the fans as they are then on full when i select game booast.
is the fact i am using a non x version of the 2700 a problem ie can they still be OC'ed and if so what is the minimum OC i can expect
