- 1 Dec 2015
Latter 3 for ram personally
If that's a 24" 4k not being used for media work then avoid unless you spend gaming looking through a sniper scope to explode up the image , believe you'll have to sit about a forearm length away from the screen to see difference over HD
Good maths if you've got 20/20 vision
https://carltonbale.com/does-4k-resolution-matter/
https://www.google.com/amp/s/www.fo...-far-you-sit-from-the-screen-is-critical/amp/
https://blogs-images.forbes.com/kevinmurnane/files/2017/10/chart_Rtings.com_.jpg
** Do Not Hotlink images **
no point spending a ton of money on a 4k monitor then to upscale windows so you can read the text haha. gaming text is the worst to- eve online with a 27" 4k monitor without playing with settings you need a magnifying glass haha
