I find grease proof paper works fineHas anyone tried the liners that are marketed? Is foil just as good?
My gut feeling was that they're not so great. The reusable ones need cleaning and the paper ones seem like a waste.They’re pointless imo. Food doesn’t seem to cook as well in them, plus ninja air fryers are really easy to clean anyway.
dishwasher on intensive i throw everything in it.
That's why i always take the lid off of frozen faggots.That can get sucked up the fan if it’s not held down properly.
First hand experience.
Even worse they can catch fire if you try to pre-heat with just the paper inThat can get sucked up the fan if it’s not held down properly.
Even worse they can catch fire if you try to pre-heat with just the paper in![]()
yes i found out this way tooEven worse they can catch fire if you try to pre-heat with just the paper in![]()
We use a silicon tray with a raised mesh thingy and they just go in the dishwasher instead.Has anyone tried the liners that are marketed? Is foil just as good?
Yeah, it's how i found out too, lucky caught in fast from the smell![]()
Have you a dishwasher? I found them a pig to wash by hand just but some might be better than others I guess..
I used to line Max Health Grill with foil but it sucked up the foil from under the grill plate!That can get sucked up the fan if it’s not held down properly.
