Note to self, don't put the paper liner in when preheating
Even with light food items it can do the same!
My girlfriend got the Ninja Stacker today, tried it out all afternoon but it cooks unevenly and it seems reviews state the same.
Its going back for the standard side by side drawer version.
Unless someone is absolutely desperate for space it does seem that the usual design is the better one.
I have a question.
You normally cook steak using a very hot pan. I have cooked steak in the air fryer and got decent results following the instructions to cook it at 200C. But as mine goes up to 240C, why does no one seem to suggest air frying steak at the higher temperature? I would experiment, but I don't really want to ruin a nice piece of steak trying it out...
you need the maillard reaction from a contact grill at 300C+ ... gas hob is the only way, like for wok cooking, induction/electric, too don't cut it;why does no one seem to suggest air frying steak at the higher temperature? I would experiment, but I don't really want to ruin a nice piece of steak trying it out...
Get a wok burner if you’ve got any outside space / balcony. With both flat and wok shaped rings for the winyou need the maillard reaction from a contact grill at 300C+ ... gas hob is the only way, like for wok cooking, induction/electric, too don't cut it;
I'm deprived of gas hob in the current property, which would also, currently be a cheaper way of cooking (was comparing smart meter, evening meal energy use with a relation only yesterday)
I’ve got the Tefal, used it for about 6 months now. Max temp is 200. It’s pretty average tbh. Decent for chicken etc but I’ve never been able to get a good chip cooked in it yet. Tried all sorts of brands but I think the fact the ninja goes to 220 / 240 must make all the difference. I might just bite the bullet and ditch it for a ninja.
Do people generally pre-heat their air fryers before using them?
Oh that’s interesting, so if I have cook a chip that was traditionally an oven cook chip, I would never add oil to the fryer. I wonder if just a small amount might make all the difference.It may not be the higher temperature setting that helps, but perhaps the Ninja is a bit more consistent at delivering 200C and circulating the hot air? Certainly I've had no problem producing chips with it. Usually make them from scratch, but when I did air fry frozen chips they came out fine.
Just a thought, but do you do all the suggested steps when cooking chips with your current model?
Pre heat the air fryer
Add some oil
Don't overload the drawer!
Shake a couple of times during cooking
I don’t, but just be aware that the 1st minute is probably not equal to the second oneDo people generally pre-heat their air fryers before using them?
The more budget lower wattage ones need it because it takes a few minutes to hit the right temperature, the higher wattage ones don’t, as they reach temperature within seconds.Do people generally pre-heat their air fryers before using them?
