Same, I don't have one installed.Still nothing here for me!
Try this https://www.sordum.org/9470/windows-update-blocker-v1-8/ and take control of windows updatesArgh it's back! How is this even possible I manually wiped away any trace, Windows Update must be pushing it through in the background??
Is the AW275DF still the go to 27in 1440p oled? Is there anything else coming in the near future that might be worth waiting on?
AW3225QF owners, have any of you had an issue with your monitor not turning on unless you unplug the power cable (sometimes for 10s, sometimes it requires leaving it unplugged for 48hrs). I've just had a replacement delivered so hopefully I was unlucky the first time.
Ah, interesting. Thanks for sharing. I suppose there are pros and cons to a monitor having an internal PSU. I'll be more wary of it moving forwards I think.I had that happen with an Asus monitor when the PSU had gone bad/faulty
Also had the same thing happen years ago with Shuttle PC's when the PSU's used to go bad
True, good thing the QF is staying put still32.9 is horrible for gaming, you get the stretched look in a lot of games. 21.9 or go home![]()
True, good thing the QF is staying put still![]()
Completely agree. I forget it has a curve as it is so subtle versus most curved monitors which are far too aggressive.. I was hugely against curves, but the price of the AW3225QF was £300+ less than other 4k 240hz OLED monitors when i bought it last year so it was a no braider.the 4k 240hz monitor is the best monitor ive ever owned. I know some people dont like the curve, but its so subtle that if you're sitting in front of it you barely notice it
Exactly, i get why people would not want 1000r or 1400r curved monitors as it does feel too much for regular use outside of gaming, but this is almost flat.Completely agree. I forget it has a curve as it is so subtle versus most curved monitors which are far too aggressive.. I was hugely against curves, but the price of the AW3225QF was £300+ less than other 4k 240hz OLED monitors when i bought it last year so it was a no braider.
