yea GCN 7970 made 30%+ during its development with drivers.
aint thinking that with 290 but more power is there to gain for them down the road.
Lets hope it doesn't take them the same time it did with the 7 series to get "mature" drivers then.
No. When are you actually going to read results that have actually used voltage control? Seriously, stop spreading disinformation.
I'd remove that as it has swearies and TTL? Come on, the guy is clearly bananas![]()
It's 95c at stock volts. God only knows what temps it will reach with added volts. Unless you're using LN2 for cooling this is not the GPU for a normal gamer / overclocker.
Hopefully the third party coolers will save the 290X some embarrassment and run cooler than 95C.
You have to see the hypocrisy, if Nvidia launched a hot card they would be flamed (See GTX 480)
AMD launch a 95C GPU and suddenly 95C is no problem, yeah great temps.
Logic has gone out of the window with this launch.
Ah ok, thanks for the heads up lol. I do think logic is lost on this release, people have red blinkers on..
95C.
Power use.
Surpassed by 780 when overclocking..
What is going on lol.
You're refusing to separate the GPU from the reference cooler, which is the least important part of it. It doesn't matter what temps it runs at, that's just showing cooler performance. Stick a cheap cooler on a 4770K and it'll hit 90C immediately.
yep 95c is too hot. just like the 7990 on air a lot wont buy it for that very same reason and most who buy it watercool. if you water cooling a 290 does look better on stock cooling the 780 is better choice.
if nvidia change pricing quickly then the 780 will sell like hotcakes. in most reviews i seen id say they about on par just that the ati card is hotter.
so save 100 ish quid for a over in your pc or wait for few weeks for cooler card and same price 780 gtx. i know what i d be doing![]()
After discussing with a friend i have to ask, were the people getting 290X cards ever really considering Titans?
Yes it's good it's beaten them, but was the performance really the thing that swayed the decision?
Dg going green![]()
TTL review sums it up from 23mins.
