TSMC yelds are underwhelming for N3 so far, Zen 5 might be delayed and the might get a Zen 4+ instead.
Zen 5 is on 4nm, not 3nm, the same as the RTX 4000 series.
Oh, I assumed it would have been on N3. In this case, it's pretty good news, I wonder if AMD is also experimenting with Samsung nodes...Zen 5 is on 4nm, not 3nm, the same as the RTX 4000 series.
Arrow Lake will also be using TSMC 4nm. I'm excited to see AMD/Intel finally compete on the same process node, where only architecture and design matter.
That confirmed? Thought they were only using tsmc for the igpu tile.Arrow Lake will also be using TSMC 4nm. I'm excited to see AMD/Intel finally compete on the same process node, where only architecture and design matter.
Yeah it won't be cheap full package is 3d stacked on the foveros passive layer.I don't think it really matters, Intel would still have to try and make enough money to keep servicing their own fabs while at the same time paying TSMC for wafers in the same way AMD and Nvidia do.
If it is true Arrow Lake will not be cheap, i'm saying that now, Intel will hope AMD blunders Zen 5, very unlikely, and then charge the a fortune for them so they can pay to service their own fabs while not using them and paying TSMC.
All Intel seems to be doing these days is desperation and hoping AMD Bulldozers something along the way.
That will be very interesting.Arrow Lake will also be using TSMC 4nm. I'm excited to see AMD/Intel finally compete on the same process node, where only architecture and design matter.
They're gonna be expensive CPUs...Arrow Lake will also be using TSMC 4nm. I'm excited to see AMD/Intel finally compete on the same process node, where only architecture and design matter.
They're gonna be expensive CPUs...![]()
Intel may further reduce their margin on desktop in order to keep/gain market share. The current 13th gen CPU's are also very expensive to make, huge monolithic dies compared to what Zen4 is using.
Ironically the Zen 4 P-Cores are little bigger than the E-Cores in 13'th gen, you can fit about 3 Zen 4 cores in one P-Core. Those 8 core chiplets about the size of your little fingernail.
If they both finally do end up on 4nm it will be good to at least truly compare differences when on same node.
Shows how much AMD are holding back so they can overcharge usIronically the Zen 4 P-Cores are little bigger than the E-Cores in 13'th gen, you can fit about 3 Zen 4 cores in one P-Core. Those 8 core chiplets about the size of your little fingernail, you get about 1,300 of them per 300mm wafer.
Sorry but Intel's manufacturing credibility has suffered so much this last decade that I will only believe it when I see it!Nodes should/could* be pretty close once Intel get 18a operational.
I.F. Intel FoundryYeah, it’s a really big if.
