Anglia Project
I would say that 5th link between the diff and the rear carrier is likely not needed and may cause some strange interaction as it is at a 3rd angle compared to the 2 forward links and the 2 links between the diff and the rear of the hub carrier.
I would test it over the full throw with and without just to make sure it doesn't try to twist the hub carrier.
The rear shock should ideally be mounted to the top of the carrier, but if you are confident those welds are not going to be under too much strain then fine.
Amazing work you have done though, Anglia was my first car so they hold a soft spot in my heart and this one is immense.
I didn't explicitly mention it, but that forward lower arm has been moved, and is now parallel to the other 2 rear arms - a minor miscalculation, and it introduced a load toe out when the suspension was loaded up! :) We found that out as soon as it went down on its wheels again!
Now that it's parallel to the other two (you can see it if you look at the below photo), there's no toe change now.
It does need the 5th link to keep everything square - remove any one of them, and the hub moves in ways it shouldn't :)
When it all comes apart again, the shock mounting brackets will have even more reinforcement added to them, whether they show any signs of needing it or not!
Sweet, thought I might have been right on that one :)
This is ridiculous and I love it!
Are you going to try and make it look like it could have come straight from the 60's inside and out? Or not too fussed about that?
Nah, not too fussed about that :)
From a distance, I want it to look mostly standard (hence the only real changes being the wheels), but I'm happy for there to be things for people to spot that are different once they get up close :)
My dad took a quick video as we were leaving the Ace a couple of weeks ago - it seems I need to get hold of his phone and set the video into HD mode, so it's only very bad quality, I'm afraid!
I've got an SJCAM 4000, but I had the waterproof case on it last time I tried, so the sound is non-existant (I've just found that the spare, non-waterproof back does actually fit properly), so next time I go out for a drive, I'll get that set up and try to get some half-decent video footage!
ah great read, haven't seen anything from this for a while so good to see a bit of action, looks like youve done a great job.
Hoping that this gives me the push I need to get mine sorted :D
Will post my own build thread when I've got a few more pics and stuff.
With the car successfully back at my dad's, I left him the fun task of playing with the bodywork.
The initial coat of primer was put on before the trip to the Ace Cafe so that it was mostly one colour, and to cover the remaining bare metal.
My dad then continued to prepare the primer for paint for a few days, with lots of late nights - I did have to remind him at one point that the colour was only supposed to be temporary (and that I was taking it home soon!), he stopped with the preparation of the primer, and started laying down some colour.
With that done, next was to add a bit of detail:
And after yet another very late night, a few coats of lacquer were added:
While this was taking place, I was busy at home giving a spare set of wheels a quick refurbishment:
With it all together, I was finally, after many years, able to take it back home with me.
The radiator still needs to be replaced with something better, but I have now been able to begin sorting some of the small niggles, and do little bits and pieces that weren't suitable to do during the limited time when visiting my dad.
The fuel gauge was being intermittent, so I have now investigated that, and found that the earth to the sender unit was not making full contact, so I have created a better earthing point on the sender body.
The Check Engine light had been on whilst driving, and when I had previously retrieved the error codes, it pointed towards the Crank Position sensor. Upon spending a little more time reading the codes, I had actually mis-counted the flashes, and it was the Barometric Pressure sensor. Upon investigation, I noticed that the MAP-ECU was not configured to output the Baro signal (on the original car, it was an additional sensor in the MAF, but that has been removed, so the MAP-ECU steps in again to perform this duty) - simply ticking a box in the setup for the MAP-ECU has switched off the Check Engine light!
I have also finally got rid of the remainder of the red paint from the inlet manifold - something I hated from the day I picked up the donor car!
My tinkering will continue - I plan to tidy up the interior - painting the dash/doors, fitting carpet, door cards, rear seats etc, as well of course as replacing the radiator.
Seems I forgot to post this one up here! Here's an update from October...
After a few more drives to get to know the car a bit better and taking it to some local meets, the first thing I did was to get a new radiator. This is much bigger, and thicker, and is bright and shiny and alloy.
After fitting it, I took it for a pootle around town to get it up to temperature, and to check that there were no major leaks. With that trial run all good, and the temperature not going much above 90, degrees C, I took it out on a run on the motorway, to see what a period of sustained motorway speeds would do to the coolant temperature.
The coolant temperature remained somewhere between 90 and 95 degrees C at a sustained 70mph, and it actually drives better at 70mph than at 50mph! This was a triumph! I'm making a note here: HUGE SUCCESS! It's hard to overstate my satisfaction.
However, all was not right - and about 20 miles down the road, a misfire started. Knowing I was only about 4 miles from a services, I thought I'd try to limp it there, so as to not end up broken down on the side of the motorway.
Yeah... that plan didn't work. Another mile down the road after the misfire started, I lost all power, and the engine just wouldn't restart.
My guess is that with the extra heat, not only the output from the better radiator, but the heat from the turbo/exhaust due to running at a higher sustained speed, one of the coil packs overheated, and therefore exploded.
When it expired, it also took out the Ignition Failure Sensor (which provides power to the ignition coils, and provides the rev counter output based on actual ignition pulses rather than "requested" ignition pulses) - so with no power feed through the IFS, that's why the engine wouldn't run, even on 4 cylinders.
I have replaced all 3 coils with new ones, a new IFS, and also fitted a "turbo blanket", which has reduced the radiant heat given off by the turbo on that side.
As well as resolving this minor electrical/heat issue, I have also been tidying up the interior, and making it more civilised.
First off was to paint both the dash, and inside of the doors, around the rear windows, and fit some carpet:
The carpet has made a huge difference to the sound levels, removing a lot of the road noise.
I also tidied up the glove box lid and dial surround with a coat of the same silver used on the outside.
I am now finishing up the remaining bits of painting in/around the bonnet - those being the master cylinder cover, central bonnet catch bracket, and a bonnet grill.
The next thing on the list will be to make up some panels for next to where the rear seats would be, and either paint or cover them, along with the front door cards.
That will then make the interior look a lot nicer, as well as being more sound deadened. Short term, I'll put some carpet in the back where the rear seats would be, but I do also have a couple of options for rear seats which I'll investigate to better tie in with the rest.
2015 Roundup and 2016 Plans
2015 has been an exciting year - it marked the culmination of many years of work, finally getting the car out of the garage, onto the road, and subsequently back into the garage again!
After my last update in October (really, has it been that long!?), I did a little more tidying up of various parts.
The brackets I painted for the engine were fitted back in place, as well as painting the post-turbo Y pipe, which really tidied up the look of the engine bay.
With painting on my mind, the next thing to tidy up was the rear suspension components, which were still in bare metal. I'd only driven it in the wet a couple of times, so before subjecting it to more moisture, time to give it a protective coat.
I decided on silver, as a contrast to the black underseal.
A common issue with the Nissan 200SX is that the centre propshaft bearing fails, and introduces noise to transmission. Whilst painting the suspension, I took the propshaft off to fit a new bearing.
I'd been having a bit of (well, a lot of) wind noise and drafts coming past the doors. The doors still have the original rubbers on them, and until I do a full strip down for final paint and purchase fresh new rubbers from the Owners Club, I've fitted an additional rubber to the door opening on the body. This also covers the bare metal edge - two for the price of one! I found to my amazement that the one set of door rubbers I acquired for this (from a Vauxhall Zafira) are the exact perfect size to go around the door opening without any cutting or stretching!
Next off I made up some interior side panels, and covered them with some grey material. I almost went for blue, but thought that the grey would make a nice contrast, and the blue might be too similar but different enough from the body colour to clash, rather than compliment!
With the paint only ever being temporary, the finish wasn't 100% perfect, and I never expected it to be. However, when a friend offered to go at it with his machine polisher, who am I to reject the offer!?
We first off gave the boot and bonnet a quick rub down with some 2000 grit sandpaper to get rid of the few surface imperfections, prior to going at it with the polisher.
With some smooth paint, it was time to head down to the NEC for the Classic Car Show, where I was invited to be on the Old Skool Ford stand.
On the way down, I stopped off to see a friend who can flash the Mitsubishi ECU, as I wanted a couple of tweaks applied.
My PLX wideband O2 sensor packed up, so it was not outputting the correct voltage to either the MAP-ECU for the wideband value (0-5v, which is only used for logging), or the simulated narrowband output (0-1v) to the ECU. With this outputting an incorrect voltage, the ECU was adjusting the fuelling to try to correct an incorrect air fuel ratio reading. With it disconnected, a Check Engine light was displayed.
So, I asked for the O2 sensor requirement to be removed, so that the ECU works purely from the fuel tables, and does not attempt to adjust the fuelling based on O2 sensor readings. This will slightly affect economy on a run, but I will not be fighting the adjustments when tuning.
Due to the work of a ClubVR4 forum member, the ECU can also be programmed to flash the Check Engine Light when Knock (pre-detonation) is detected. This gives a good indication to the driver (me) if there is something wrong with the fuelling or boost level that causes pre-detonation of the fuel in the cylinder.
With the computer hooked up, we did a couple of 3rd gear full throttle power runs to see what was what, including with a working wideband O2 sensor hooked up.
The Mitsubishi ECU calculates "load" based on RPM, throttle position, and airflow (amongst other things). On a typical Galant VR-4 doing a full throttle run, this Load value reaches around 240.
However, during our runs, this value only reached around 120!
The boost was also only reaching around 5psi, when it should be around 10psi, and the Wastegate Duty Cycle was at 100% trying to build up a higher Load value. The Wastegate solenoid is activated by the CPU in a "pulsed" mode to bleed off pressure from the wastegate to increase the overall boost pressure. This shouldn't be at 100%, so it's indicative of something not right!
The replacement prop bearing had made a positive difference to the noise level, but during the drive back from the NEC, there was still noise coming from the rear, and as I approached home, a new noise started. I stopped off to get some milk (having been gone for 4 days), and when I stopped I noticed that the hand brake wasn't working as well as it should. Additionally, the passenger side rear wheel was warm to the touch, but the driver's side was rather hot! I had suspected wheel bearings were needing a replacement (they had been sat outside with the 200SX rear subframe for a few years, exposed to the elements), so the car was tucked up in the garage, and not touched again until the new year!
First on the agenda for 2016 was to look into the handbrake and heat on the rear wheels. I stripped the rear hubs down to check the handbrake, and noticed that the cable had come away from the hook on the floor it should be hooked over. As I lifted the cable back into place, I noticed that the handbrake mechanism moved slightly within the driver's side rear hub. This movement in the cable had been applying the handbrake slightly - causing the heat I felt. So, securing the cable to the hook, I slacked off the adjustment on the lever to give a mm or so of free play, and readjusted the handbrake mechanism on both rear wheels again.
Next was to look into the issues that may be causing it to be down on power. Firstly I looked at the boost solenoid, and found that it was stuck solid. Usually this switches on/off very quickly every second - the more it's "on", the higher the "Duty Cycle", and the more air is bled away from the diaphragm trying to push the wastegate open to allow exhaust gas to bypass the turbine within the turbo. Bleeding all the air away (100% duty cycle) will cause the wastegate to stay shut. With the solenoid stuck closed, it was bleeding away none of the air, so the wategate was being pushed open at 5psi - the strength of the spring which pulls it closed.
I took the solenoid apart, freed it up and put it back together and tested it on the bench but it still didn't work properly when in the car. One advantage of having a Legnum VR-4 as a daily car, is that I've got a full engine bay of spares! And, as luck would have it, the boost solenoid isn't being used on the Legnum, as I have an aftermarket electronic boost controller, which has its own solenoid valve, leaving the standard one connected, but not in use. So, I was able to swap the two, and I now have around 10psi of boost - a reasonably healthy increase over 5psi!
I have also purchased a new wideband O2 controller, and a mechanical boost gauge from ETB Instruments to match my existing dials, which I have fitted, replacing the old.
And that's pretty much up to date. There's still more to do (isn't there always!?)
I have, however, decided that I will be participating in a few (if not all) of the Old Skool Ford Drag Championship this year, which is being held at Santa Pod alongside a number of shows.
This will be a great opportunity to have some fun in the car, see what its performance is like, improve both the performance of the car and my drag racing skills, and provide a target for getting improvements and fixes implemented, and probably most importantly, meet some new people and have a laugh doing it!
So - I may see some of you at these events during the year! I'll keep you informed here how I get on with the championship, as well as the trials and tribulations of it!
I've just spent the past 2 hours reading this. It's seriously impressive what you've done. Whilst I really dislike the car in general, I absolutely love this!
We need some videos of you driving it properly.
Oh, I really hate the way you've done the pictures :p
I did put full size photos up originally, but I ran out of bandwidth every time I posted an update! So I changed to thumbnails, sorry!
I've been out with it tonight, and have logged 11.3psi of boost, so a great improvement.
I'm planning on making a video soon :)
Adjusting the handbrake helped with the noise and temperature, but the rear wheel bearings still needed replacing, so I stripped down the rear end to remove the bearings.
And then went a bit further...
I figured whilst I was there, I'd remove the rest of the brakes and tidy up the backing plates and calliper carriers.
Continuing with the process of trying to eliminate noises, I found that the throttle cable was tapping against both the turbo heat shield and underneath of the bonnet. So a couple of extra cable ties will secure it better and stop it making a noise.
Since I fitted the new radiator, I didn't like that it was visible from the front of the car. It was slightly too tall, but extra size is needed for the cooling capacity, so a section of the front panel beneath the number plate was removed. But, as the radiator was bright shiny aluminium, it stuck out like a sore thumb, and I was frustrated with it.
So I finally got round to disguising it with a squirt of black paint.
And, finally, there's a nice shot from the front, so here's one from the back too.
And last but not least, the interior as it currently stands, with the new ETB boost gauge.
