Tried different cable?
My monitor shows lots of horizontal interference lines when it first comes on. They go away after about a minute but it's obviously not a good sign. Don't think it is a graphics card or pc problem as this happens when only the monitor has been off. any ideas?
Good point about the cable. I'm using a 3rd party cable from a reputable company but I'll switch back to the bundled cable just in case. I'd be happy if just needs an easy fix
Glad I'm not the only one that has had the horizontal line problem, it started off as a small problem but has been getting worse as time goes on lasting longer and getting more lines. What confused me was why it was only doing it after booting, didn't occur in bios or in windows boot up, turns out (on mine at least) it was the refresh rate. Changing it to 60hz, problem goes away entirely, back to 75hz and it returns, sometimes even worse than before I changed it. Using the bundled display port cable as well.
edit: I should note that after the monitor has been on for a while, the problem doesn't return when changing, it's only after it's been off for a bit.
Pretty much exact same as mine. Although ive noticed the lines getting worse and staying for longer.
And a few happen at the windows boot logo.
I think ill just RMA it to be on the safe side. Its only 10 months old.
the semi-glossy is VA, not TN.
the VA is what most have.
have you tried to underclock/overclock the freesync range?
can you try it and post your results?
I'm using the bundled cable and have the issue. Tried different monitor with same cable and no issue. Let me know how you go as I might just organise AOC to collect it.
