One thing that has occured and which may be an issue is that when I first ran the monitor this morning all appeared to be in order i.e. picture and blue 'on' light when after a monitor (NOT gpu) electrical 'click' the picture went black, the monitor then advised 'no signal' and blue became red - then after a few seconds it switched itself back on i.e. picture and blue light.
It then ran without issue for 40 mins.until I decided to switch off.
Tonight same 'event' but has now been running normally for over an hour.
Anyone got any thoughts as to what is going on ? and should I be worried?
I thought that to have 60hz I needed DP1.2?Mine was also playing silly beggars at the start. I disabled DP1.2 via the OSD and everything went back to normal.
Nope. DP1.1 will do it - as I am currently.
Ahhhh - Ta for this; may well give it a go with 1.1
(I believe that I had confused the requirements of a 4k monitor with this one; which does not have as many pixels)
No you weren't confused. The u3477Pqu is limited to 30Hz at its native resolution unless you're using DP1.2. At least that was the case on my GTX 970.
I'm looking to return the monitor unfortunately. The light bleed is way too distracting for a £600 monitor. There's also an issue with the display port and DP1.2, the screen goes mental, flickering, buzzing (electrical noise) and goes blurry.
Using DP1.1 locked with the menu it's stuck at 30Hz until I force a custom resolution to allow 60Hz but it's a bit of a bodge to be honest.
It also struggles to wake from sleep with windows 8.1 and the inbuilt USB hub has occasional issues with devices that aren't recognised after it sleeps, it needs powering off entirely via the manual switch.
Had none of the issue with my previous BenQ XL2420T
I had to add a custom resolution of 3440x1440 at 60Hz. DP1.1 works fine.
Have you got it working without issues on your 970 with DP1.2 ? Mine goes mental trying to use 1.2. I did read there was a hotfix from Nvidia on an older driver but I haven't tried installing it yet as I'm doing OK on DP1.1
*edit* I thought it was an Nvidia issue, maybe it's not http://linustechtips.com/main/topic/221663-run-aoc-u3477pqu-at-60hz/
Update: I have now tested this on a GTX 980 and R9 280X. Using regular DP cable on both. Guess the problem lies with the monitor. I asked AOC for a firmware update, but no answer so far.
Is it 1.2 only or does it have 1.2a? I can find no information about it.
