I have finally put my PSU back in properly and closed the case back up. Just tried the Hitman 2 demo, if I have Vsync on (I normally do, cant stand tearing) then the load of the GPU is only around 70 percent and the temp gets up to about 79-81 with fans on 100 percent.
I just tried Vsync off, was getting upto 120fps with 99percent load, but the temp got up to around 86-87 after 10mins and was throttling the boost down under 2000.
Is there anything I can do to try and improve cooling? I have a 200mm intake up front, 1x small intake on the bottom in front of PSU and 2x exhaust fans at the top. Then the CPU is exhausted out the back with the AIO cooler.
My concern is games that will actually load the GPU to 100 will be throttled due to heat
I am thinking, maybe I should stick a AIO cooler on it with one of those brackets.
I also had a couple of crashes today but that may be because I OC the memory a fair bit, reset that back to 0 now.
Thanks,
Sean
