Depends, how is the air flow in your case? This graphics card throws out TONS and TONS of heat. Its scary, when i touched the side of my case it was hot. The graphics card also heated up my nvme drives. Check the temp of your hard drives and see if they are ok or getting any temperature warnings.
I would put the graphics card into a manual fan curve where anything over 80c and 100% fan, yes its loud but you dont wan to be running anything over 80C long term not good for your card, even though Nvidia says anything blow 89C is fine.
Get more airflow in your case, its a must with this much heat kicking about.
Fans are already on custom curve with 100 speed at 80c lol.
I have a 200mm intake on the front, 120mm intake on the bottom. 120/140 exhausts at the top and a 140mm exhaust for the cpu AIO out the back.
I still have space for another intake on the bottom and one more exhaust at the top but I dont think they would add much as they are not really over any components.
HWMonitor to check m.2 ? I have 2 ssd and a mech drive but they are all out of the way. m.2 pretty close to the GPU I suppose.
Thanks.
