Caporegime
- 1 Dec 2010
- Welling, London
Think I've decided on a 3800X/Master combo. Hopefully, it will come in at under £800.
Price would be also certainly decent amount cheaper without all the garbage.If cooling/VRM is overkill - shouldn't be an issue like x370s so no need to contemplate removal - was relatively simple with a friends x370 when he upgraded. I would rather see the exposed heatsink's fins, fully. They should showcase the hardware rather than cover it up with plastic and lights - or at least have a barebones/minimal release for us boring types.
Yay, finally Gigabyte got BIOS flashing without CPU.
LOL - i pretty much imagine you as the Finnish equivalent of him when reading your posts about INTELSomeone should really take proper grip from ties of marketroids and explain to them in best R. Lee Ermey style that from that point on they're not allowed to do anything, including breathing, thinking or opening their mouth without permission.
Yep, @GIGA-Man will be pleased too - he won't get alerted so much with requests.Yay, finally Gigabyte got BIOS flashing without CPU.
Yes, FFS that looks awful (design and look) - especially for me with brick coolers that expel out the back. I could expel out the top but would negate some of the silent properties of my case. If i do buy the Pro it will be the first thing l look into - but not attempt immediately.But once again you need to remove that plastic garbage to make justice for VRM cooling.
Should make it under the wire if 'predicted' prices of Master prove correct.Think I've decided on a 3800X/Master combo. Hopefully, it will come in at under £800.
I’ve got 3200 sticks.Should make it under the wire if 'predicted' prices of Master prove correct.
You're certainly going all out - the Master looks a quality designed/equipped board, you should have no issues getting your 3600 sticks to optimal 3733MHz.
Ah, the Samsung b-die predator kit? (CPU forum discussion)I’ve got 3200 sticks.
Yep, that’s the one. Apparently they’re a piece of cake to hit 3600 with, so a bit of tweaking and I could hit 3733. Interested to see what I can get the CPU up to as well.Ah, the Samsung b-die predator kit? (CPU forum discussion)
From reviews/forum clocks you shouldn't have any overclocking issues - good choice.
8 Cores is my limit/need - undecided whether 3700X or 3800X - like the idea of chancing the 3700X with clocks.
Looks that way - it was when he powered the demo mode, showing RGB - but suspect this pleased both parties.@Plec should be fine
Looked at same board - was hoping it would drop below £200 but with the increased interest in x470s, for reasons above, doubtful. Will this not be in the ballpark of the Pro at that price (~£220)?Friend just went and got Aorus x470 Gaming 7 ... Saw the charts here, asked roughly the price of the new ones, eyes up the x470 board and got it . Considering I had 3700hz running on mine he's happy to go for it...
Master looks very nice - the board i'm considering not so much and loving the exposed thermal pads look under sinks(i know, will be tidied on release).
:/doubtful ! like everything else made in china, time is money and pads are a bit on the thick side so will spill a little when pressure is put down on itbut you shouldnt see them when the board is in the case.
Surprised if they don't tidy spillage - only requires a stencil cut once specific shape has been worked out (but appreciate would add additional time for placement). Especially on top tier boards...
Don't tell @tamzzy - he's already stressed about paint matching - poor sod had an idiot use the side of his car as a parking guide and the damage may eat into his Zen budget. If he see's the thermal pad spillage it may finish him off...
@Plec lol. Not interested in the ATX sized boards
I'll just have to work extra shifts to pay off the paint job on the car.
Still intending to get the 3900x - pending reviews
