- 1 Dec 2015
@Mensy Aorus Pro has WiFi on one version as well as the Ultra at under £300. Unlike the Strix which is £340 and no WiFi !!
From his posts he wants an ITX build so the 'Gigabyte x570 i' would be a winner - but with yet to be announced price he may need a whisky and beer chaser attached.@Mensy Aorus Pro has WiFi on one version as well as the Ultra at under £300. Unlike the Strix which is £340 and no WiFi !!
depending on budget, might not be able to afford said whisky and beer chaserFrom his posts he wants an ITX build so the 'Gigabyte x570 i' would be a winner - but with yet to be announced price he may need a whisky and beer chaser attached.
Make the whisky a blendeddepending on budget, might not be able to afford said whisky and beer chaser![]()
might as well down bleach insteadMake the whisky a blended![]()
lol - perhaps make it a Boilermaker if needed.might as well down bleach instead![]()
As you've waited this long you may as well compare performance reviews, as the odds are it will fill your brief for ~£100 less.I can get a msi b450i and flashed from a local computer shop
After watching buildzoid's breakdown of the Elite it seems like a great board considering it's bottom of the stack. I did him review the Pro yet but didn't seem overly fond of the Ultra.
It will be interesting to see the price difference between the Elite and Pro, in theory both should be capable of running 16 core.
How does the X570 Xtreme workout in the PCIe lanes I looked at the manual but it only points to describes that the 1st slot runs x16, 2nd x8 and 3rd x4, If I use 2 gpu's will the first run at x8?
Yeah he more or or less said skip the Ultra and the Strix as they're identical to the lower versions in terms of VRM.
Personally I'm hoping the Taichi comes in at Strix/Ultra prices. It looks outclassed by the Master and Crosshair, but they're overkill for my needs (3700x on an H115i).
So is there not an ATX pro with Wi-Fi?
don't think they have lol...not with advanced mode anyway...Jeeez , finally they have sorted it by the comments above !
hint of /sarcasm right thereOfcourse within classic mode...
