They’re now showing a Rev 4 with a new mounting kit causing no offset fitting issues;
https://support.arctic.de/lf2-240r4
Hopefully this should be available shortly for those awaiting a fix. It would be nice to get some new MX-5 thrown in too to refit it.
I wonder how much is to do with the offset mounting and how much is to do with the MX-5 paste?I've now received my Rev 4 mounting kit for my Liquid Freezer II 240 and it fits great on my MSI B550 Gaming Carbon Wifi. Loads of clearance for the caps at the top & no interference with the M.2 slot & heatsink. I've fitted it in the offset position, which I couldn't do before. I also bought some of the new Arctic MX-5 paste.
My BIOS remains the same with PBO2 enabled with a -30 all core negative curve. The temp on my 5800X has dropped by 5°c under load (now max 79°c / idle 27°c) in Cinebench R23 but that isn't the whole story as that is now with all cores running at 4775Mhz whereas before they would only get to 4675Mhz. Single core boost remains the same at 4850Mhz.
Just ordered some MX-5.
Ok, thanks for the update, might cancel my MX-5 order then, as I have enough paste.The only review I’ve seen had about a 1°c reduction from MX-4 so I put it mainly down to the offset. If the cores weren’t boosting higher I think the temperature drop would be bigger too.
Just contact Arctic customer support, I am sure they'll send you one they are very good.So where can I order Rev2/Rev4 mounting kit? I have a rev2 240
Very nice, I've found their customer service excellent.I've received today my Arctic replacement parts and even though I only requested a few missing washers and screws, they sent me a full kit for both Intel and AMD + a fan. All of this for free on a second hand product bought off eBay at half the price (they knew as I had to provide proof or purchase).
Not bad.
http://imgur.com/a/tKamwHg
That's a good improvement.5C difference on a 3900x using the same type of paste
