ATI cuts 6950 allocation
NEw rumours say this
. power consumption lower than gtx 580
. Temperature not so desirable
. beats gtx 580 Slightly
. card longer than 5870
. idle temperature 45c
. 6+6 pin connector???
Additionally, if the 6970 is £400 odd like people are speculating, that leaves a massive "gulf" in the £200-£300 region. Realistically, I can see the RRP of the 6970 and 6950 to be around £240 and £300. That leaves room for around a £400 RRP for the 6990, if it's dual 6950s, as their dual cards are always under 2x the cost of the single GPU versions.
1GB 6950 would fit in nicely around £250 with the the 2GB 6950 at £300.
Can I get source with that? :) If it's any longer than the 5870 I might have to settle on a 580 (if I can lay my hands on one).
Gibbo has already said it's going to be £350 - £400 for the 6970.
This is in line with the 5870 at launch (now £180!).
Edit:
Mr Krugga said:
That is very untrue, HD5870 was launched at $399, Gibbo's quoted pricing suggests $479-529 which is a lot higher than HD5870 launch prices.
AMD are making huge margins on the 6870 currently.
The die size is 255m^2.
It's primary targets are the GTX 460 and 470, with die sizes of 366m^2 and 529mm^2 respectively.
If Nvidia are still turning a profit on selling 460's for ~£150, then we can only assume that AMD are making ample profit from the ~£200 6870 cards.
AMD could argue that the gap in the £200 - £300 region can be filled by Crossfire solutions (dual 6850 or 6870), this also makes SLI GTX460 an alternative for this price range.
We won't be seeing a new set of 28nm graphics card until the end of 2011 at the earliest.
TMSC say 28nm production will start in Q2 2011 but most chips require at least one respin.
Hmmm just had a thought, if Raven is telling the truth? Will the 6950 actually be faster than a 580 like early neliz rumours?
If the above is true I doubt we will see a high end dual GPU card from Nvidia either until 28nm...
It's very unlikely IMO. I would opt for HD6970 being 12-15% faster than GTX580 and HD6950 approximately 9-10% slower. That is assuming that HD6970 is 65% faster than HD6870 compared to 45% for GTX580 and the difference between HD6970 and HD6950 is around 20-25%.
So when AMD have massive availability of their probably faster card and Nvidia can't even make theirs in large numbers, the best strategy is to price them so high the volume is low and it makes a 580gtx look not terrible value?
If AMD have volume to shift (and nVidia have little to none) and a faster card they can price it up, consumers will pay more money for a faster card especially if they have a hard time finding stock of the alternative.
If AMD were doing business the way you suggest why is the 6870 more expensive than the competing cards from nVidia?
