Does ATI Tool support the X1950XT ?
1337z0r said:Ok cool, a issue i found with ATT is you cant push the memory more than 900 .
Concorde Rules said:Drivers
Omega Drivers Site - For 98/ME/2000/XP
I strongly recommend using these drivers!!! They use the latest ATi Drivers which then are slightly modified, old control panel added and ATi Tray Tools added aswell. Its everything a ATi user needs.
Standard ATi Drivers - For 98/ME/2000/XP.
CCC (Catalyst Control Center) has issues with ATi Tool 3D Detection - I don’t recommend using Standard ATi Drivers unless using Crossfire, then I think you need to use ATi Drivers + CCC.
b.cummins said:I'm just curious if there is still limited crossfire support on the OMEGA driver set. I'm pretty fed up of CCC and I'd like to have crossfire running in OMEGA. Any recommendations?
geeza said:Im running a sapphire X1800XT with arctic cooler X2
Catalyst 7.1 drivers
ATI Tool 0.26
I am currently running 700core 800memory with default voltages
voltages show the following in ATI tool-
Vgpu 1.375
Mvddc 2.097
Mvddq 2.097
I idle at around 54/55 and load goes to around 71 highest in gaming. Should I try raising the Vgpu a bit to get more on my core clock?
ShiWarrior said:you know on this ATT, overclocking setting, u say their are 3 tabs, I only have 2, no voltage tab on mine
HIS X1950 PRO pcie
delbuenno said:My connect x1900xtx clocks to 689/797 using CCC and nowt else. Runs at around 80degrees C (which seems hot to me). Ran 3d mark 06 with it and got 6023 but during the penultimate graphics test the whole screen kept going white!? so will lower the clocks a bit
What kind of max Temps do those of you using the stock cooler get?
