- 1 Dec 2015
I'm playing catch up - but looking good, Orbi.
Is that the PSU's definite siting now? - Seems the best of both worlds and looks good in situ practicality wise (once covered).
Yeah - will need to extend the hex holes at the back or just hack off some more vent area for the PSU
Shame about the PCIe riser cable but it looks like it's taken its fair share of abuse this past week.
can see copper wires at 3 of the edges at both ends , just to much bending at 90 degrees and come out of casing/resin - though looks still attached
You are going to have to incorporate, permanently, a bit of Lego into this build - even if it's only pseudo propping up the GPU. As mentioned - i'm sure i've seen a build with a Lego Figure (Iron Man/Hulk would be cool for your kids) propping up back end of GPU.
haha - 92mm fans should hold it as well as recycle some supports within the GPU stock mounting system
Have you reached a decision re panel/plexi - and rad?
Also, what's the plan/news for the new front fascia?
Will cut one cut i think. may need Silverstone to send another case- maybe a broken one or parts - top fascia and side panel would be helpful . that was mount like Thumb-less Glass panels where they are glued onto a metal frame which bolts to the back of the case
*Did you remove backplate of GPU for more space - or do you think it's required?
will keep backplate as thats no issue and kids love RGB so will be able to see it via the back
i cant believe the ram is taller then the PSU mounted to the board. makes it 65mm high all in from case bottom ! need to drop a new set in but hard when the kit is 4000hz B-Die !
