What does BTC purchase stands for in this context? The only BTC I know is a BitCoinHow does that even happen? It’s a legit BTC purchase ?
Sorted by Overclockers support, no fuss generated new code, downloading now this chonker as we speak but won't get to play until tomorrow morning... time for some space PocahontasGood luck.
Been playing it today, exceptional in my opinion.
Unfortunately I'm having to use the older 23.11.1 AMD driver as the 23.12.1 caused my system to grey screen on start up, I've got everything cranked up to the max at 1440p with my 7900 xtx pushing AVG 130-150fps, I assume it would have been better with the newer driver as says it's optimized for Avatar.
Only issue I've come across is a tiny bit of stutter when moving the camera, certainly playable tho and not hindering my experience
It's his editor - Shill Up gives the reviews he doesn't want to do to Austin.Not sure who Austin is, but I would have preferred to hear from the OG skill up dude.
Is that with frame gen ?Been playing it today, exceptional in my opinion.
No I wouldn't say it is, I've put a couple of hours in to it now, you get skill points that you use for improving your character.Better question, is it just another Far Cry clone? I really dont wanna spend if its just another far cry clone.
Yes it isIs that with frame gen ?
I took out a drilling station, now I'm not sure if that's a "outpost" so to speak but I haven't come across any map scanning points.
Arrow crafting Is the same as AC tho
It is indeed but you are contradicting yourself ????? means you are asking us and !!! is telling usThis game is absolutely awesome?????!!!
