- 4 Aug 2005
ok i'l give that a shot and see how i get on, cheers
firmware uploaded succesfully, im even syncing higher aswell which is nice!
just out of curiousity bobby did you have to change your VCI to 101 and change to LLC-BASED in the adsl settings tab?
well on adsl2+ i'm sync'ing at 15mb down and 1.3up so it's not bad and speedtest looks good,
after looking about on Be's forum i see a guy had a similar problem changed his antivirus from AVG 7.5 (which i have) to avast and his problems were solved, will give this a try later i think.
any thoughts on why i'm getting the random spikes every couple of mins and it's rock solid otherwise?
hmm, maybe it is my AV then it's strange will give avast a go later and report back with the results, bloody Be* never had these problems with my BT line and had ingame ping of 7 aswell, only reason i switched was for the higher upload and download speed now i have higher ping, lag spikes![]()
Did you read these posts on the BE Gaming forums?i'm really starting to tear my hair out with this problem now
I had a coupl of DNS issues on Be last night aswell :|. All of the speed tests I do report my line speed at 3-10Mb yet I still download at 1.55MB/Sec... slightly off base![]()
You could put an entry in the hosts file for bebox.
Your SNR margin isn't that great (not that it's bad either, it's bang on the default target SNR margin that Be set) - if it fluctuates much it could be the cause of the problem too (though I thought Be had Seamless Rate Adaption enabled), especially if you've lost 1000kbps from your sync rate.
