Caporegime
I have my car back! Brrmmm!
£6,400, I did get a full tank of fuel too
You don't get a code per se. You have to have it coded which will require additional kit. Quote often it's something independent garages will have.Morning Guys
I picked up a 2014 5Series mSport the other day with pro nav but no enhanced bluetooth, can I get a code for this as the BMW dealer said the hardware is there but not enabled?
Thanks
Thanks, I've had a look online and with the BMW ENET Coding connector and the E-sys software it looks fairly simple to doYou don't get a code per se. You have to have it coded which will require additional kit. Quote often it's something independent garages will have.
EBT? Passenger and driver or?Although you can enable it there are hardware differences, EBT fitted cars have dual microphones.
Ah OK so I can enable it and stream from my handset but the voice side of things won't change?Ebt is enhanced Bluetooth
what were you doing? round round round around the roundabout ?Nearly stacked it twice this morning. Must have hit a diesel slick as all rear grip just went. Was just after a sharp bend. Same place each time.
Lol pretty much! Went to get fuel at a station just off a roundabout.what were you doing? round round round around the roundabout ?
It's not a big service it's just oil and microfilter.
