F10 servicing costs...
I've just called for a price from Knights BMW to service my 63 plate F10 520d, it's on 75k miles now and has had 4 services previously.
£530/540ish - I was too shocked to take in the exact amount, once I heard it start with a 5 my head fell off.
Is this normal? I'll be calling around other dealers on my lunch break if I get chance but this just seems like an absurd amount for an oil service and filters (+ visual inspection).
Am I just behind the times, my 3.0i Z4's and E46 only ever cost arouod £340 for an inspection I!
To be honest, from going from the BMW Service website it's £454 for the oil, oil filter, fuel filter, air filter, then £79 for the vehicle check. So £530-540 is bang on. I do (not) like how BMW have now made a "visual check" a separate chargeable item - when it used to be a given that this would happen as part of any vehicle service.
I never used to get it done. I'm not paying £80 for someone to get the torch in my glovebox, check I have enough screenwash and make sure my first aid kit is in date. The only people who I can imagine would be happy with this service are people with huge amounts of money, who also don't know *anything* about cars. Not to mention, most of the things they "check" would immediately flag up on the iDrive if it was low or not right! This is the full run down of what you pay £80 to a main dealer to do - which from what I've heard from people who used to work at dealers, doesn't get done anyway:
- Checking horn, headlight flasher and warning system - Pretty sure you can do this on your driveway.
- Check instrument lighting, passenger compartment, luggage compartment and glovebox lighting. - And this.
- Check function of rear, rear and license plate lighting - Another tough check.
- Check Seatbelts, including strap, function of reel, locking reel, buckle, clip and clasp. - If you can't do this, maybe a chimp can help?
- Check windscreen wash and wipe for function and settings. - Sigh.
- Check Tyres for tread depth, wear pattern, external condition and inflation pressure. - This again isn't difficult.
- Check first aid box and expiry date, and warning triangle. - 20 seconds work.
- Check engine coolant level and concentration, top up if necessary. - If you can unscrew a lid from a jam jar, you can do this. Concentration won't have changed unless you've dumped litres and litres of water in.
- Check headlamp and windscreen washer fluid level and top up if necessary - Apparently BMW felt this needed to be a separate check from "Check windscreen wash and wipe function" above. Almost as though they're trying to make the list of things longer when you glance at it.
- Check steering fluid tank oil level (if applicable) - Can you wiggle the steering fluid reservoir around to see the level inside? If so, great.
- Check brake lines and connections for tightness, damage and correct position - MOT's will flag anything up like this.
- Check under vehicle body, including all visible parts for damage, correct position and tightness - This, at absolute best, consists of a BMW mechanic wandering around under your car for 15 seconds.
- Check steering components for play, leaks, damage and wear. - An MOT will flag this.
- Test Drive - Check for road safety, including brakes, steering, shock absorbers and gearbox. - Do your brakes feel sharp? Does your steering turn well and the car generally feel stable? Does your gearbox change gear?
- Exterior is washed - They do this anyway with a regular service, and normally scratch the paintwork.
- Interior is vacuumed - They do this anyway with a regular service and miss most of the stuff.
- BMW Service history is updated....and wallet is noticeably lightened.
