Possibly.. Didn't really spend long enough to judge.@leoncuprar smell like burning curry?
It might not be egr I could be jumping to conclusions. From a quick check seems the recall was for cars upto June 2015, mine was registered Nov 2015..but I'll call my local dealership to enquire.Any recalls outstanding? I'm pretty sure there's a big recall for that car/year to do with the EGR.
No need to call, just check on the DVLA website.It might not be egr I could be jumping to conclusions. From a quick check seems the recall was for cars upto June 2015, mine was registered Nov 2015..but I'll call my local dealership to enquire.
Thanks
I'd still contact BMW if it is the EGR valve they are replacing them under goodwill even if the car is outwith the dates of the recall.
Yes, although I don't think it is anything to do with EGRSo , 65 plate F10 with 44k on the clock..
Started up this morning and got a low coolant warning.. so had a check and yes sure enough I can't see any in the coolant chamber with the high/low markings..
I have noticed a funny smell when exiting the car , the last couple of nights when getting home so I wonder if that is related.
Anyway, I have no coolant in the house but there is a garage around the corner.. so I can get going again.
A quick google seems to suggest it might be an EGR issue so I'd better get it booked in with BMW to check.. anyone else suffered with similar on their F10 ?
Thanks
fairly sensible
Yea, definitely get a 12 year old BMW.
You are lots of fun...Yea, definitely get a 12 year old BMW.
The engine makes the car really (and they're fairly reliable on that front).
Handle well, make a dramatic noise given the right intake/exhaust but ride poorly and are tiny inside. If you can make do with fiesta levels of space inside (so probably kids that are well out of rear facing seats and don't have anything other than a tiny buggy) it will be ok.
You can buy a chinese android/idrive replica upgrade for assuming nothing already in there should you particularly care about infotainment, albeit they are of questionable quality and not cheap to do.
I'd have one, but they're not going to be a classic
So if your spending money and want something more sensible why not get something a bit more modern and less likely to break purely based o age?I've currently got a 12yr old Renault, what's your point?
