Quite. It worked when it they took it in, now it doesn't. Their problem entirelyConsidering it was a recall for a problem I'd expect the car to be returned in a better & healthier state than it was handed in tbh.
The error code was:probably depends what the error code was ? if it said idrive/ccc reset for unknown issue that is symptomatic of impending hardware failure,
but a firmware upgrade, might thermally stress system, which has been rumored to accelerate that failure, what do you expect dealer to do.
It has the larger screen, not as far as I know but I purchased the car used so it is a possibility. Do you think the issue is that the recall has reset the coding back to factory settings?What size screen is it? Has a larger pro screen been retrofitted at any point? If so it may be looking for the incorrect size screen, hence it now being blank.
Any advice on whether next BMW should be a diesel or not? Usually do 15000 miles a year, thinking 330d Touring but maybe hybrid more sensible in the long run?
usually lease them so new and assumed s/h prices are still sky high?New or used?
That seems like a lot of money for a 5 year old, last gen 3 seriesseen this one not too far from me, might have a look tomorrow. Not checked on lease prices yet.
Thanks, just noticed that trying to get lease quote! Shame. new 320d crazy money anyway so going s/h 330d.BMW have stopped the 330d![]()
got rid of my 530d Touring a few months back (great motor) so now using my wifes 420d convertible, the hardtop one so about as practical as a you know what, and i can't get the bikes on the roof!What do you currently drive?
looks like latest gen are £35k mark? I was thinking more like £25k.That seems like a lot of money for a 5 year old, last gen 3 series
not a bad callG31 530d? Early ones are around 25k now.
