- 19 Oct 2002
- Shakespeare’s County
What colour is that?
Dravit grey.What colour is that?
In the metal the iX looks amazing! I was going to change my order colour to 'Storm Bay' but the standard white looks great - roll on November !
Engine/spec? Looks good!Picked up my X5 at the weekend. As above its definitely a step up from the X3 both in size and build.
M50i, nice V8 right there.Its a 5 month old M50i, spec wise it has Ivory Merino leather, Tech/comfort plus packs plus quite a few other bits and pieces added on. Importantly it has the factory fitted tow bar so can drag the caravan around.![]()
Very nice! Good work on the V8 instead of the diesel!Its a 5 month old M50i, spec wise it has Ivory Merino leather, Tech/comfort plus packs plus quite a few other bits and pieces added on. Importantly it has the factory fitted tow bar so can drag the caravan around.![]()
Very nice! Good work on the V8 instead of the diesel!![]()
Got a rear air suspension issue on the G31 this morning, both sides are down and chassis error in idrive
Never used the insured warranty before, but will give them a call shortly. Does someone normally come out to you (I have the roadside assistance too) or are you expected to take it to a dealer if it's deemed drivable?
Upper 40s on a run I’d say. Depends what you set cruise to.What sort of fuel consumption should I expect from a G31 530/540d xDrive Touring? Low-30s around town and low 50s on the motorway?
