Deleted User 298457
Deleted User 298457
BMW auc bites again...useless.
Are you all saying that the insured warranty is useless?![]()
Furthermore, I would have expected to be treated as if the warranty was managed and approved by BMW (I.e. like the AUC), since it was purchased through their website and treated as a renewal of the AUC warranty.
I don't really understand your point here, in my experience there is no difference to the customer in how it's handled, the difference is in what is and isn't included. If you made a claim for a part that wasn't covered under the approved used warranty, like for example wheel corrosion, you'd get the same thing?
How it works in the background shouldn't really be visible to the customer and in my experience it isn't.
How was it a renewal of the approved used warranty, you said above when we discussed the choice of excess that it was a new policy (which is why zero excess wasn't offered and why it was more expensive).
I don't want to come across like I think you're unreasonable being annoyed. I'd be annoyed as well, I have the same policy and same headlights are you. I find it annoying they have this exclusion. I'm just trying to explain my opinion on how it works.
That’s possibly my fault for not understanding, but when other brands are offering extensions to their warranties, I thought that was what I was buying. Left a sour taste in my mouth.
I can see your point but not many brands offer an extended warranty that isn't based on this same insured system. A look at the small print of almost any manufacturer warranty will show that it is underwritten by an insurer and not the manufacturer.
There really is very little that is covered under the approved used car warranty but not covered under the insured warranty.
Cross posting from the tyres thread
Costco having a promotion on Goodyear tyres
Just booked in my car for 4x AS6 19" (225/40, 255/35)
Total damage was £496 which is the cheapest I've ever seen them
why is this? curious to knowYou may have issues getting these fitted if they are not BMW star marked.
Ah that makes sense now...the guy that booked me in was asking loads of questions about RFTs and all that and something about voiding BMW warranty if non-RFTs fitted.Costco can be a bit funny about what they will or won't do when it comes to fitting tyres, like only fitting manufacturer spec tyres, only fitting factory sizes, only fitting new tyres to rear if you're replacing two (staggered setups obviously excepted)
