Cleaned car and stupidly left the key in the ignition, went to start it to move it and nothing but clicking. Jump start time...
http://www.autotrader.co.uk/classif...00/page/1/fuel-type/petrol/make/bmw?logcode=p
Any good?Looks like a decent example as far as I can tell. Not sure about the make of tyres though.
Good deal for someone; main dealer too:
http://www.autotrader.co.uk/classif...ified/maximum-age/up_to_5_years_old?logcode=p
Well it doesn't matter anyway because on the way there he rang and let me know he'd sold it! I'll keep my eyes peeled.
What have you got Jez? You had a 325 didn't you?
When you turn the car/lights on do you see the headlight beam go up then down when it adjusts for the auto levelling? If no, your auto levelling sensor might not be functioning properly. If yes, you can manually adjust the height of the beam on the back of the headlight.
How long have you had the car? How long has the beam pattern been so high? Since both of headlights are too high, I think the auto level sensor is a good call.
They're OEM xenons yeah. I'll try out the sitting in the boot test too! Will I be able to see the lights themselves move during the ignition sequence? Cheers for the help.
Is the E83 X3 based on the E46?
Just keep in mind that they tend to be considerably more expensive than the equivalent e46 - not many (any?) petrol manuals about either if that's an issue for me.
Not a car I've got a lot of love for if I'm honest, not because it was bad....more because it just wasn't that good at anything
