Anyone?![]()
Can you not stump for a 330? The 325 is a bit of an odd machine. Not much more performance than a 320 - more refined certainly - and not much more frugal than a 330 but with markedly less performance.
Anyone?![]()
I'm coming from a 1.6 so felt the power jump was enough for me to be honest. I'm assuming it would be more thirsty on petrol also? Along with being more expensive overall?
You're looking at about a second quicker to 60. Fuel consumption is nigh on equal - autotrader gives the 325 an average of 39.8mpg, the 330 39.2mpg. Tax I believe is equal for them both.
It's a far better engine and if you hunt about you'll find one for exactly the same price as the 325 you're looking at.
Anyone?![]()
Don't buy a car from someone who thinks runway tyres are good.
http://webcache.googleusercontent.c...s-6mm-/300642696002+&cd=3&hl=en&ct=clnk&gl=uk
Unless oem are extortionate I can't see any reason to go elsewhere for rear pads
Why wouldn't you fit oem pads yourself? What's the labour portion of that £220?
I'd have no particular problem with oem equivalent, depending who made them.
