There was another cab I saw with OEM nav but this one doesn't and I'm getting more value out of this one with the extras and buying experience going with this dealer.
I don't mind if the UI strays away from an OEM experience, the OEM nav screen ui is dated and doesn't really say much anyway so having the Android UI skinned on the Andrive unit is going to be much better for me. Most of the time it will only be displaying the playing music info anyway and all other times Google Maps as I don't really need or care about any other screen other than those two
In a way this creates less faff for me because if it did have OEM nav, then I'd need to spend another £50 on a fakra cable and route it into the boot where all the audio components are located for stock nav cars. As it's Business CD only, everything is in the dash so simply a direct swap-out.
C63 pics, Sunny?
[TW]Fox;27381478 said:You can haggle with the dealer over the AUC warranty. I have a 2 year AUC warranty on mine as a result
Pics Soon!!
Maybe we should arrange for a meet and take pics of our cars together
So, I'm still toying with the idea of a 2009 335i (or 2010 if I can get my hands on one cheap enough), but I'm also concerned about the size so I am considering the 2009 and 10 530i's... The 09 still have the old idrive but seeing the posts about the android software, would this make the system nicer (I understand its a replacement system)? Would there be any benefit at all? Can it integrate with the sat nav systems ok (how does that work, presume you can get an app that will do the nav for you?) and does it integrate with the little joystick?
[TW]Fox;27383449 said:Whilst they do offers such systems for the E60 I really wouldn't be pulling iDrive out in favour of one...
Even the crappy 1st gen?
Thats the thing its not the latest sat nav system but its still integrated and can still get map updates, includes phone/bluetooth and has the car management options. Thats going to beat most 3rd party systems just for simplicity and doesn't involve you pull the car to bits to fit it. If you've not had the later CIC or NBT systems its still an "ok" system.
