Just so you know, rumour has it that BMW won't be providing any further map updates for CCC satnav past the recent 2015 release.
Why would that be the case? Pretty sure they are still providing updates for the system in the E39, E53 and E46...?
You can retro fit the latest NBT iDrive into the E6*/E9* with a special wiring kit.
[TW]Fox;27385833 said:Why would that be the case? Pretty sure they are still providing updates for the system in the E39, E53 and E46...?
2015 maps for the CCC will be coming shortly.
Also, 2015 is the last year for MK4 and CCC navigation systems. After this update BMW will no longer support any navigation system older than the CIC system based on the information they've put out about it.
You can but at a heavy cost, from memory CCC to CIC is about £1k in (used) parts alone, would imagine CIC to nbt would be of at least a similar order, then the coding if you can't do it yourself.
There also used to be some missing functionality with the nbt conversions not sure if its been changed now
The cost is similar to retro fitting the CIC system. The NBT hardware is fairly reasonable available for around £600, the adapter kit puts the price up as it is pricey for what you get but one kit is supplied with a self coder so it is plug and play.
It could be complete rubbish hence why I said it's only a rumour, but it was posted recently on e90post by Dracon, the forums resident BMW satnav guru. Apparently they're stopping the MK4 updates at the same time:
[TW]Fox;27385961 said:Wow, seems a bit odd, people with Mk4 computers got a far better deal then as it's been years since new cars were supplied with them.
I'd imagine people with 2010 X3's might be somewhat annoyed by this though - buy brand new car, lose map updates just 4 years later
good call on the manual too
Why? Genuine question. Reliability?
I assume mostly because it's a manual and more involving
Does seem like an odd move. Stopping MK4 updates I can understand as even the newest cars with those fitted should be about 8 years old now, but like you say, there are much newer cars fitted with CCC.
I presume that the LSD in an E46 M3 is a Drexler? If so, does it have a service schedule and associated tickbox in the service book?
I'm curious because I don't ever recall seeing it mentioned before when people say what to look out for when buying.
Developed jointly by BMW M GmbH and GKN Viscodrive GmbH, the Variable M Differential Lock offers superb traction in demanding conditions. In conjunction with the Dynamic Stability Control system and 50/50 weight distribution, the new M3 delivers handling in slippery conditions formerly regarded as impossible with a rear wheel drive sporting car.
