Need new pads on the front
Sent an email to the pirates at BMW to see what price they'd charge!
Failing that, anyone know a good UK website to order some pads and a wear sensor from? Other than euro who seem to have nothing but pagid! F30 328 btw.
Question - probably aimed at Robbie actually....
Weisslicht Spektrum. They look ace on your E46.... any ideas if they will fit the front indicators on an E85 facelift?
Hmm they don't have E85 (only E89/E84) on their fitment list bit if the volt/wattage and pin layout is the same as another model there's no reason why it shouldn't work!
Do you know of another model that has the same bulb as yours?
Aye aye it will look good! Hopefully the fitting type matches another so easy swap
Folks, tentatively looking at BMW for my next car choice.
With a budget of £11K-£12K, what would be a good choice from BMW? Ideally I'd like 2/3 doors and some performance. Been looking at 135i coupe and E92 320 coupe but not very clued up on the range. What's the best looking E92 outside of the M3?
E92 335i - should get one for that money i'd think.
306bhp, maps well should you wish, good toys etc etc. Personally I'd not get a 320. Get the 335i if your going to get that model of car
Or ofcourse a 135i (same engine) if you like the looks of it more. But the 3 will have more toys as standard.
Obv I'm biased having owned a 335i for 3 years and I loved it.
Thanks pal. Honestly, not a fan of the 1 series but it's a little more palatable in coupe form. I'll check out the 335i
Edit: manual or auto? Always had manuals but am tempted with an auto, or at least to try one. Can the auto still be sporty or is manual the one to have?
I owned a manual - but most are autos (you get flappy paddle with autos so you can retain control if you wish)
There is an SE and an Msport model. This is basically trim. The SE for a 335i has a number of the things the Msport has though, where as an SE for say a 320 wouldn't.
So 335i wise, Msport adds different wheels, bodykit and I believe steering wheel / gear knob if manual.
The 335i SE still has the Msport suspension, front sports seats and black headlining.
So what I'm saying is, don't be put off by an SE in the right colour / spec just because it's an SE
[TW]Fox;27630543 said:They are such terrible value though, 12k gets you a car that's almost 10 years old which seems mental for a 3 series.
Does anyone know if it's possible to get 5L of BMW screenwash with anti-freeze for less than £19.99 delivered?
