Not necessarily. They could be running epic poke...
They fit fine, what's the fuss about it?
I believe they will use the "Any item that has worn out rather than suffered from a defect" as a get out for it. They don't cover coolant or fuel hoses either.
Repair or replacement required due to a gradual reduction in the operating performance of a covered part, commensurate with its age or mileage.
i checked the brakes section of the warranty and it made no mention of pipes so assumed they wouldn't be covered, i will try tho!
[TW]Fox;27811331 said:If you have Comprehensive warranty there isnt a list of whats covered, just a list of what isn't.
i looked at the individuals and just checked the brakes section, unless more bits are covered on fully comp that arent noted on the site.
That feel when the traffic immediately ahead is still, but then it opens up to allow the rev needle to tickle 5-6000rpm for a moment and you're in a narrow road with walls and some buildings either side to bounce around the exhaust note![]()
Thanks for that, I'll sleep better now.
mrk do you have an m3? Pics?
*whoosh*
Only an Audi m8.
Here's our new M3, got it in November. Love it. That's my son in the pics checking it out just after I brought it home.
Only put 2400 miles on the clock since Nov.
[/QUOTE]
Looks stunning in red. :cool:
