Looks like its XE fighting time with the facelift 3 series and all new engines other than the 330d.
http://www.autocar.co.uk/car-news/new-cars/2015-bmw-3-series-facelift-revealed
Oddly their 320d with 161bhp is only 99g with the auto rather than 102g for manual. In contrast to the Jaguars 99g manual / 104g auto.
Fox will love the fact the 2.0 turbo petrol is no longer the 328.... but now the 330i!
Well they have caught up.... Sat Nav as standard. Guess that has to reflect on the base price.
[TW]Fox;28009295 said:It's only 1200 quid on the 3 and 5 LCI.
What would put me off retrofitting is the faff with warranty etc.
understandable, but not many reports of them failing and its 20 mins to fit the old one back in.
the coding as I understand it is almost entirely specific to the NBT, when I swapped the hardware all that was changed was the model of head unit and the enabling of black panel support from the new unit.
there are numerous other data buses on the car as you know and all functions are working perfectly on my car as a whole
perhaps I am in the minority on how little coding was required on mine, but I felt it might be helpful info for others entertaining the idea.
I hadn't allowed for the "purists"
[TW]Fox;28009529 said:The issue is that if the dealer needs to do a vehicle integration update it can fail if you have retrofitted things. Whilst this is fine if everything is planned if your car goes duff at the side of the road and is collected and requires new parts at the dealer it can all get quite messy.
Meaning that retrofitting items like that is best avoided if you wish to maintain and use warranty.
I looked into it to see about retrofitting the combox.
[TW]Fox;28006210 said:The prices are already low, under 10k easily gets an early one now.
Yep, because you can guess where the finger will be pointed for any faults and what the response will be before you have to start arguing that installing x didn't cause problem y..
The posts regarding firmware updates and retrofits are highly inaccurate and shows a lack of in depth knowledge on how ISTA or SSS works when it comes to programming BMWs.
When retrofitting something in a BMW you run a retrofit command, this retrofit command comes as a package, in that package the most important thing is the CCM being updated with the retrofit.
Once everything is completed there will be zero difference on ISTA/D or DIS between a vehicle that has had something from the factory and something aftermarket.
So when you do go into SSS or ISTA/P it will see everything that needs updating and go for it. That will automatically include your retrofit.
Programming does go wrong but it will never be because of the retrofit.
