Sounds promising, thank you. It didn't click at first that something like shocks could cause issues with the steering.
Any particular brand you would recommend or just stick to OEM?
OEM should do the trick if you're not lowered. I believe the standard ones are Sachs ones which you can get from ECP and GSF. Avoid the Monroe ones which are similar money but promise a more comfortable ride - they're not worth it.
