Are you confusing the black panel display with the multi function display? Couldn't get MFD on pre-LCI cars as far as I know.
LCI comes with black panel as standard and MFD is optional extra
You could get the MFD on the pre facelift cars.
There are decent lease deals out there.
[TW]Fox;28715507 said:You don't need to be a cynic - it's a laughable comment that that M6 will appreciate. It won't. It'll plummet.
Mostly updates the maps on the CIC version.
On CIC High, it adds more apps like Spotify
I get a few random petrol stations, usually when I'm painfully low on fuel too![]()
[TW]Fox;28671305 said:I have a 530d, my Dad has a similar age 520d. His is a slightly heavier touring. His is about 5-10% more efficient than mine. The 530d is significantly quicker - paired with the 8 speed box it's far quicker than you'd expect (It's 0-60 time is a good 2 seconds quicker than the 520d). It is also noticeably more refined - i hate diesels, I can tolerate the 530d.
This is where the problem arises. IMHO the 530d is a noticeably better engine and far better suited to the car but it's also quite significantly more money than a 520d which makes the decision far less clear cut.
The 520d is affected by the infamous chain snapping issue. There are no major known issues with the 530d yet but frankly they are so ridiculously complex I'm not prepared to run it without the BMW warranty therefore don't really care.
No with one exception - the pre LCI cars have the most horrendously crap plastic around the base of the seats that squeeks if you touch it. This is fine on a car with regular seats as you never touch it but if you have Sport seats the side bolsters apply pressure to the plastic when you corner and therefore you get the squeek. Very annoying.
It's a great car. I can't see me wanting anything but F10's until they all get old and crappy.
