so electrician in work came and asked me what i thought of m5's.
I shrugged and said aye nice cars.
he is looking to spend about 20k on one about 08 or 09 plate.
what is he likely to get for that. something decent?
The guidance is 50 miles but you can drive much further than that on them flat.[TW]Fox;28800849 said:If you get a puncture you can run on flat for 50 miles - so no arriving at your destination if its further than that..
They don't suddenly turn into a pumpkin at 50 miles![]()
I did, unknowingly and it lasted up fine. Sure I wouldn't choose to travel hundreds of miles but there will be a safety margin built in to the 50 mile guidance. It's probably safe up to +20 to 30 miles.[TW]Fox;28808252 said:The sidewall is only rated to hold the weight of the car for distances of up to 50 miles.
You go right ahead and drive hundreds of miles on a deflated runflat tyre - I'll pass, thanks.
The lease on my 320D efficient dynamics runs out early next year. Seen a good lease deal on a 420d mpower, anyone recommend that car?
[TW]Fox;28800849 said:This is the common rationale behind retaining runflats but IMHO it is flawed.
With a conventional tyre unless it's blown out you can almost always re-inflate the tyre and drive on for some distance - usually to a tyre shop to effect a repair.
So either way if its dark, wet and raining and you've got a long way to go you won't be going a long way with a puncture irrespective of whether you have RFT's or not.
The RFT's on the F10 are better than they ever were but the other problem is tyre availability - there are almost no good tyres available in the size the F10 on 19's takes. You end up stuck with Goodyear Excellence, Michelin Primacy or Dunlop SP Sport MAXX.
No CS5's, no Pilot Super Sports, no Eagle F1 A2, etc etc...
[TW]Fox;28810028 said:Its the same as the car you already have, just a different trim level and with 2 less doors (or a hatch back).
So you already know if it's any good.
There is nothing 'M Power' about it.
I'm sorry Fox, but the flawed logic here is that a non run flat is the better option.
