Am I right in thinking there may be some good deals on stock F11's now that the new 5 Series has been announced, or is it a bit too early?
Bit too early, I've not really noticed a change in price, it's a haggling point though...
I like to remind you guys....We get it, you drive **** loads of miles in a truck![]()
That's just perished rubber from rancid neglect! But I'm a bit dubious about the chips in the metal frame underneath it, has someone been trying to poke it off themselves? That doesn't look good...
If it's anything like the rubber trim that runs along the front windscreen, then it doesn't actually do anything to seal the glass in like the gooey strip between glass and frame. Autoglass should be able to replace this trim piece no problem.
The rear glass won't have anything special, you won't need to replace any sensors either as they are not fixed to the glass, they are modules that simply detach. The replacement windscreen has the correct "window" for them to sit in.
Having said that, someone might come along in a bit and go "all of the above is completely wrong"![]()
330d to an M140i. Would I regret it?
It's a 2014 F31 M sport with auto. Reason for thinking of a change is that the car was the 'family wagon' but now the missus has a car we generally use that to haul the kids.
[TW]Fox;30116059 said:And on that note, insert obligatory photo of F10 in Far North of Scotland last week
http://i1005.photobucket.com/albums/af176/Foxtbh/applecross_zps7df5cyho.jpg[img][/QUOTE]
You must have done that on purpose..... :p
