So the parents e46 320 petrol (2005) is using oil..Around 1L every 1000 miles (more some times). This can't be good....I've read on a few of the enthusiast forums that this is not uncommon for this model of bmw. Has anyone had this issue before. It's only done 75k...
My E86 drove me almost insane with the multitude of rattles and squeaks.
Mines not too bad, odd noise here and there. Most come from the rear and the roof mechanism which is to be expected I think. Don't think the harsh drive helps it though, go down a bumpy road and it will rattle for a little while afterwards before settling down again.
Still think the interior is lovely in design only let down by the lack of a decent non ipad screen but that's down to its age so cant hold it against it really.
I can't get over how epic this car is...
Could someone please explain what happens with Eco Pro mode? I'm addicted to using it and getting that bonus range up...will have some proper fun in Sport plus mode this weekend
It almost feels like the car is coasting and has some power going to it when I take my foot off the pedal. It loses speed so much slower than I'm used to say with the Jag, where as soon as you stop applying any throttle, the car loses speed quite quickly. Also, with the EfficientDynamics, what is actually "charging" when I apply the brakes?
1. The sun visors when folded up vibrate against the plastic giving that leather sticking to plastic sound. I'm thinking some velcro tabs stuck in the corners might space it enough to stop this.
I'm sure I saw someone did a little project stuffing a small android tablet where the Sat nav pop up screen is.
Thanks guysthe coasting feels really nice, takes some getting used too but makes driving more efficiently a breeze.
The gear box is just brilliant, it's so much better for town driving than the XF. Gone are the days of random kick downs or delayed acceleration while it works out what gear it needs to be in when coming off roundabouts or sharp turns etc
It's just a dream to drive in comparison, and the smoothness of the engine for a diesel is just crazy. And have I mentioned how good the HK sound system is?!![]()
Yeah I made the same switch and you definitely won't be disappointed
Even the ride is infinitely better than the XF, it actually makes the XF seem like a very cheap car in comparison.
This is one I do have, I just tap it once and that normal stops it. Most of the interior noise is drowned out by the engine noise (good noise or vanos tapping).
I've seen something like this before, not sure how good it is though and mines not got the satnav as I wanted the basic stereo so I could easily upgrade it.
