**Borderlands Pre Sequel** SHIFT keys in first post!
What time does the game unlock tonight?
I know its going to be an all nighter tonight as I got the day off tomorrow :D
Is it better to save golden keys for when you reach max level?
It depends, I've often found that keys used during the leveling process are quite useful as they speed things up, particularly when you're on the first character. Furthermore, at max level, you're in the "end game" and you must farm unique items, the purples found with keys just don't cut it anymore.
Yeah I'd spend them randomly.
Maybe use one every 5 or 10 levels if you didn't find a good gun, and it'll carry you to level 50, you can also store them to use on an alt.
If you set your profile to read only (in the games folder) you can grind all your keys, re-set your profile back and you still have your keys
We did that in BL2...also using the Orcz site, at one point I had 150 keys on my BL2 2nd character
