busy week for you then, ![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
Wow! Looks epic , how the hell does the gpu connect to the mobo when it's placed like that ? I'm looking at the same case hopefully , what's it like for dust filters are they easy to fit ?
You use a PCI-E riser. Basically an extender of the slot. Glad it's hidden well enough.
My overall experience with my Parvum has been pretty good tbh. With it being a custom case for an ATX board it took a while to get but well worth it. They are very roomy cases and you'd be surprised on how easy it makes building the computer when you can remove the roof as well as the front. The dust filters are sandwiched between the front pannels. Basically just the magnetic ones you can buy from OcUK. They are removable but they involve you taking the front off via unscrewing allen bolts. That's my only gripe with the case. Having to remove then replace millions of screws each time you want to take a pannel off is a ball ache. well worth it aesthetically though when you're all done!
Nice ! It most definitely is, sweet build ! I'm gonna wait to see what amd and nvidia do in summer (390x/980ti) then go from there! Been looking at these cases for a while now, like you said the aesthetics are top notch bet they look amazing in person ! Those dust panels then , do you have to cut them out to sandwich them in between ? As they come with a magnetic strip don't they round the side , and this case all fits together flush?
And I don't think I'll mind all the screws as Ive been using an antec 902 for the last 5 years the dust filters are a nightmare haha , fans are starting to make a bit of a racket now too!
Not really no. They come in like 240mm sizes which are the ones I have. There is a groove for it to just sit in there nicely. So its just a matter of placing it there and then putting the front panel over.
The case is pretty much flush yes. There is a bit around the back where the psu fits in that is a tight gap but thats because I had to run wires behind the psu to get to the correct places as well as hide them. If I didn't do that it would be flush yes.![]()
