Building my first pc
lol were not stevo, well only out of myself
stevo cpu cooler and locating the power switch header next step ok^^
you should power it up to test before putting it in i say
yeh try making a innuendo out of that grant! ...o wait
He shows where it goes but not how to screw it in and stuff, I have the hard drive bay out, I just donno how to get my ssd on it, Can i take off one of the little pins at the side?
GOD only a couple of the scre holes are aligned
Don`t forget to insert the IO shield. Place the motherboard in position. Push the board tight up against the rear of the case, making sure the shield remains in position. Insert 1 screw top right corner and 1, bottom right corner. Just screw them in , just enough so they don`t fall out. Now you can move the board slightly so as align the rest of the screws. Once you have them all in, then you can start to tighten them. Just tighten each screw a little at a time, so you screw the board down evenly.
