Building my first pc
how embaressing, I was looking for an 8 pin and it was a 4 got it in :)
Are you sure about that, i am looking at the manual and it shows an 8pin cpu connecter. The 4pin you have used, does it have another 4pin connecter attached. This is the psu to cpu connecter you should be using 1 x 4+4-pin ESP/12V CPU.
You are right,but the manual shows an 8pin.
is there some kind of chat we can use instead forums? I have cam on laptop so could actually show you the computer
You're making this harder than it needs to be (as the Bishop said to the...).
The only connections you really need to check it's going to work (and get you into the BIOS) are:-
  1. CPU fan to motherboard CPU header.
  2. Two power connections to motherboard.
  3. Power connections to GPU if required.
  4. Case power switch header.
Worry about everything else once you know it'll boot.
